ALO audio Pilot
Methuselah
ALO audio wprowadza model Pilot, czyli miniaturowy DAC/AMP na ES9281CPRO, który obsługuje MQA oraz ma diodę LED, która informuje o próbkowaniu. Ma USB-C oraz adapter na Lightning.
ESS Sabre DAC (9281CPRO with MQA support)
SNR: 120db
THD+N @ 0.0006%
< 2 ohm output impedance
PCM sampling frequency up to 384kHz
DSD sampling frequency up to 5.6MHz
MQA (Master Quality Authenticated) Support
Features
Aluminum Enclosure
USB-C Termination
3.5mm Jack with Mic Support
USB-C to Lightning Adapter Included
LED indicator
Blue = idle or SD audio <= 48kHz
Red = HD audio > 48kHz
Magenta = MQA content
Compatible Operating Systems
Android / iOS
Windows 10 / Mac
