mykupyku Opublikowano 18 Marca 2016 Zgłoś Udostępnij Opublikowano 18 Marca 2016 https://www.indiegogo.com/projects/nuprime-multi-zone-wireless-audio-system#/story obsługuje pliki do 24/96 obsługa min. Spotify, a Tidal i Soundcloud wkrótce sterowanie pod iOS i Androida no i najważniejsze - kosztuje w promo: 49$ plus 18$ wysyłka /można kupić 2 w tej cenie i wtedy ship tańszy Features Wi-Fi Audio Adapter Wi-Fi 802.11 a/b/g/n dual band 2R2 RJ45 port Decode high resolution music formats 24-bit/96kHz Multi-zones Party Mode (sound synchronization) DLNA compatible Over-The-Air firmware upgrades from internet Select between WPS and Direct mode / Reset WPS & Direct Mode (AP mode) LED Display: One multicolour LED (Yellow: Booting, Flashing White: Connection, Stable White: Connected) Internet radio service (Tune-in service via companion App) Accessories: USB-A to micro USB cable 80 cm. Power requirement: 5V - 1A (via AC adapter not included). Compatible with standard 5V USB charger and NuPrime digital port. Size: 130 (W) x 80 (D) x 30 (H) mm Requires usage of Android or iOS tablet/Phone Inputs:1 X 3.5mm Analog Stereo Line-In with re-streaming capability, controlled by APP. Outputs: 1 X Optical SPDIF and 1 X 3.5mm Analog Stereo Line-Out (OdBm) sharing the same output jack 1 X Coaxial (SPDIF on micro USB connector). Compatible with NuPrime digital port for data and power supply Comparison with Chromecast Audio ($35) WR-100 has RJ-45 for wired internet streaming WR-100 has analog input for re-streaming WR-100 can operate with its own WiFi network in AP mode. Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
