all999 Opublikowano 30 Lipca 2015 Autor Zgłoś Udostępnij Opublikowano 30 Lipca 2015 Za hedfajem: http://tieba.baidu.com/p/3925490142Some information copy from Fiio Official Tieba in chinese, I translate to english外观造型及结构接口:三维尺寸: 128mm X 64mm X 16mm.Size : 128mm X 64mm X 16mm.显示屏: 4英寸IPS显示屏,分辨率800*480Monitor: 4" IPS Panel Display, Resolution 800*480机身材料: 全航空级铝镁合金,CNC一体化成型加工工艺。表面阳极拉丝/喷砂氧化处理。10 万级钻石切边工艺。Chassic Material: Aircraft Level Aluminium Alloy, full CNC machining. Surface Anodized & brushed, Sandblasting processing. Diamond trimming processing.重量: 不超过250克。Weight: less than 250g.按键: 全功能硬件按键,包括电源,播放暂停,前进/后退,音量加减。Physical Button: Full function buttons include: Power , Play/Pasue , Forward/Back , Volume接口: 3.5mm耳机接口,3.5mm线路输出 (LO)接口,3.5mm同轴数字输出接口,平衡输出接口(可选),11PIN Micro USB接口 (带底座扩展功能)Connector: 3.5mm phoneout, 3.5mm lineout (LO), 3.5mm spdif coaxial out, Balanced output (Optional), 11pin MicroUSB (inclube Docking extend function)系统与软件功能:System & Software function:基于安卓4.4系统。OS base on android 4.4独立的HiFi引擎技术,完全不受安卓系统底层对音频格式的限制。Dedicated HiFi engine technology, Playback music file format will not limit by Android System Framework limition独立的音乐播放APP。Dedicated Music audio player APP支持第三方音乐播放APP,如网易云音乐等,以实现歌曲在线下载,歌词/封面自动匹配等高级功能;Support third-party audio player APP, User can using third-party app to listen music online streaming and other music playback function支持经过验证和许可的第三方安卓APP的安装和下载;Support certificate verified third-party android app install and download支持DLNA播放,支持NAS播放;Support DLNA playback, Support NAS Streaming playback支持第三方的桌面/壁纸美化APP;Support third-party UI / Background Image App (don’t sure this meaning launcher)支持手机遥控;Support remote by MobilePhone支持自动OTA推送系统升级;Support System update by OTA mode音乐播放能力:Audio player function:内置的音乐播放APP支持Default audio player APP support function:DSD/DXD/DTS/PCM/WAV/WMA/APE/FLAC/ALAC/AAC/OGG/MP2/MP3等格式。DSD/DXD/DTS/PCM/WAV/WMA/APE/FLAC/ALAC/AAC/OGG/MP2/MP3 Music format采样率/位深硬件原生支持到384kHz/32Bit. 软件支持到384kHz/64Bit.Hardware Native support up to 32Bit / 384kHz playback, software decode support up to 64Bit / 384kHz playbackDSD支持到DSD128硬解,支持ISO直接播放.DSD playback support up to DSD by Hardware Native, support DSD iso file playback.对任何不支持的音乐格式或者采样率,均可通过安装第三方APP来解决。User can install third-party audio player APP to playback all non-support music format or non-support sample rate file by Default audio player由于基于安卓的开发平台,RK3188的强大运算能力,以及DAC对383kHz/32Bit的硬件支持能力,理论上没有X7不支持的音乐格式了。Due to android software framework, RK3188 cpu powerful processing power and DAC chip 32Bit / 384kHz native convert function, X7 non-support audio file format is very rare.系统存储信息:内置32G 高速FLASH内存;Onboard 32Gb Flash Memory.内置512M高速程序运行RAM;Onboard 512Mb RAM外置TF卡槽,支持最高128G。理论上支持未来的256G/512G TF卡;External Memory MicroSD slot support, support up to 128Gb MicroSD card. Feature support 256Gb/512Gb MicroSD card支持云存储;( 需要等后续通过固件升级支持)Support Cloud Storage (This Function support in future update firmware)支持DLNA网络播放;( 需要等后续通过固件升级支持)Support DLNA audio playback (This Function support in future update firmware)支持NAS网络播放;( 需要等后续通过固件升级支持)Support NAS streaming audio playback (This Function support in future update firmware)有线/无线连接:Network / Wireless network support:支持2.4G WiFi;Support 2.4G Wifi支持蓝牙音频播放;Support bluetooth device playback支持USB 2.0数据连接;Support Data transfer by USB 2.0支持USB 2.0 USB解码,支持192K/24B 异步USB解码;Support USB 2.0 USB DAC for PC, support up to 24Bits/192kHz async USB DAC function.支持底座扩展;Support External Docking.基本硬件配置:Based Hardware specification:主控: 瑞星微RK3188. 采用28纳米半导体先进制程工艺;4核1.8G处理器。CPU: Rockchip RK3188, 4 Core 1.8ghz processorRAM: 512M内置存储: 32GROM: 32G外部扩展: 128G TF卡。External Storage Extend: 128G MicroSDDAC芯片: ESS9018 8通道 384K/32B DSD硬解芯片。全球目前性能最高,价格最贵的DAC芯片;备注:非手机厂家所用的ESS9018K2M解码芯片;DAC Chip: ESS9018I/V转换: 待定I/V : TBD低通滤波: 待定LPF: TBD电压放大: 取决于不同的配置;Gain AMP: Depend on different module电流放大: 取决于不同的配置;Current AMP: Depend on different module内部电池: 3700mAh不可更换电池;Internal Battery: 3700mAh, NOT replaceable.续航时间: 取决于不同的输出功率配置/接口。最长12小时,最短5小时;Battery Life: Depend on output module/interface. Max. 12hrs, Min. 5hrs充电电流: 大于500mA, 推荐2.0A电流以获得最快的充电速度。Recharge: More than 500mA, Suggest using 2.0A to recharge标准配件:1,数据线;2,清水套;3,屏幕保护膜;原厂独立配件:1,各种配套平衡耳机线;2,各种耳放模块;3,充电底座耳放;4,定制的高端耳塞;发布计划:Released Plan:8月7号香港音响展做静态展示。August 7 : Dummy display on HongKong Audiophile show.9月13号广州耳机展有新品发布会;September 13 : Product Released meeting on Guangzhou Headphone Show9月18号北京音响展有产品展示;September 13 : Product Tryouts on Beijing Audiophile Show预计9月底针对VIP用户和老客户优惠发售;Estimate In late September, Discount Promotion for VIP user and post-customer计划10月全国上市。12月圣诞节前全球发售。Estimate October, Release in China,Estimate December before Xmas , Release in world Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
ALTON Opublikowano 30 Lipca 2015 Zgłoś Udostępnij Opublikowano 30 Lipca 2015 Mało ramu Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
hibi Opublikowano 30 Lipca 2015 Zgłoś Udostępnij Opublikowano 30 Lipca 2015 ćwierć kilo Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
all999 Opublikowano 30 Lipca 2015 Autor Zgłoś Udostępnij Opublikowano 30 Lipca 2015 Mało ramu ćwierć kilo Będzie mój! Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
retter Opublikowano 30 Lipca 2015 Zgłoś Udostępnij Opublikowano 30 Lipca 2015 Za hedfajem: http://tieba.baidu.com/p/3925490142 Some information copy from Fiio Official Tieba in chinese, I translate to english 外观造型及结构接口: 三维尺寸: 128mm X 64mm X 16mm. Size : 128mm X 64mm X 16mm. 显示屏: 4英寸IPS显示屏,分辨率800*480 Monitor: 4" IPS Panel Display, Resolution 800*480 .... 计划10月全国上市。12月圣诞节前全球发售。 Estimate October, Release in China, Estimate December before Xmas , Release in world A można było jakoś po ludzku a nie krzakami .... ygląd i strukturę interfejsu: Trzy wymiary: 128mm x 64mm x 16mm. Wymiary: 128mm x 64mm x 16mm. Wyświetlacz: 4-calowy wyświetlacz IPS o rozdzielczości 800 * 480 Monitorowanie: 4 "wyświetlacz panelu IPS, rozdzielczość 800 * 480 Materiał korpusu: Wszystkie samoloty klasy stopu aluminium-magnez, zintegrowany proces formowania CNC. Anodowane szczotkowane / piaskowanie utlenianie. 100000 diament proces przycinania. Material :. Samoloty Chassic Poziom Aluminium, pełna obróbka CNC powierzchni szczotkowanego anodyzowanego i, piaskowanie diamentowe dla obróbki kadrowania przetwarzania .. Waga: nie więcej niż 250 gramów. Waga: mniej niż 250g. Kluczowe: pełny funkcjonalny przyciski sprzętowe, w tym mocy, pauzy, przód / tył, Dodawanie i odejmowanie. Objętość Przycisk fizyczny: Pełne przyciski funkcyjne to: Power Play / Pasue, przód / w tył, Tom Interfejs: gniazdo słuchawkowe 3,5 mm, 3,5 mm wyjście LINE (LO), interfejsy, 3,5 mm wyjście cyfrowe koaksjalne interfejs, stracić równowagę Interfejs (opcjonalnie), interfejs USB 11PIN Micro (z rozszerzeniami stoisk) Złącze: 3.5mm phoneout, 3.5mm lineout (LO), Koncentryczne wyjście SPDIF 3,5 mm, wyjście symetryczne (opcja), 11pin MicroUSB (inclube dokująca funkcję przedłużenia) Oprogramowanie systemowe i funkcje: Oprogramowanie systemowe i funkcje: System Android 4.4 oparte. Podstawa na Android 4.4 OS HIFI technologia silnika niezależne, całkowicie wolny od ograniczeń bazowych Android formacie audio. Dedykowane HIFI technologia silnika, odtwarzanie plików muzycznych w formacie nie ograniczy przez Android ramowego systemu limition Oddzielny odtwarzacz muzyki APP. Dedykowany odtwarzacz audio Muzyka APP Obsługa odtwarzacza muzyki innej firmy APP, takich jak Netease cloud muzyki, tak aby osiągnąć piosenki do pobrania w Internecie, teksty piosenek / Pokrowce zaawansowane funkcje, takie jak automatyczne dopasowanie; Wspieranie innych firm odtwarzacza audio APP Użytkownik może za pomocą, innych firm aplikację do słuchania muzyki online, przesyłanie strumieniowe i inne funkcje odtwarzania muzyki Pomoc sprawdzone i licencji do zainstalowania innych firm Android App i pobieranie; Certyfikat Wsparcie weryfikowane przez stronę trzecią Android App zainstalować i pobieranie Obsługa DLNA, odtwarzanie, wsparcie dla odtwarzania NAS; Obsługa DLNA, odtwarzanie, odtwarzanie Pomoc NAS żywo Wspieranie innych firm stojące / tapety upiększanie APP; Wspieranie innych firm UI / tła obrazu App (nie pewny to znaczenie wyrzutni) Obsługuje telefon komórkowy pilota; Wsparcie zdalne przez telefon komórkowy OTA System Push umożliwia automatyczną aktualizację; Wsparcie Aktualizacja systemu przez trybie OTA Muzyka możliwość odtwarzania: Odtwarzacz audio Funkcja: Wbudowany odtwarzacz muzyczny obsługuje APP Domyślnego odtwarzacza audio, funkcji wsparcia APP: DSD / DXD / DTS / PCM / WAV / WMA / APE / FLAC / ALAC / AAC / OGG / MP2 / MP3 i inne formaty. DSD / DXD / DTS / PCM / WAV / WMA / APE / FLAC / ALAC / AAC / OGG / MP2 / MP3 Format Muzyka Częstotliwość próbkowania / nieco natywne wsparcie sprzętowe do głębokości 384 kHz / 32-bitowy. Software wsparcia dla 384 kHz / 64bit. Wyposażenie Natywne wsparcie do odtwarzania 32bit / 384 kHz, wsparcie dekodowania oprogramowania aż do 64-bitowej / 384 kHz odtwarzanie DSD wsparcie DSD128 rozwiązania sprzętowego, który obsługuje odtwarzanie ISO bezpośrednio. Wsparcie odtwarzanie DSD do DSD przez native wsparcie sprzętowe, odtwarzanie plików DSD iso. Dla wszystkich obsługiwanych formatów muzyki lub stopy próbki, mogą być rozwiązane przez zainstalowanie innej firmy APP. Użytkownik może zainstalować odtwarzacza audio innych firm APP do odtwarzania wszystkich plików częstotliwości próbkowania nie wsparcie formatu muzyki lub nie pomocy domyślnie odtwarzacza audio Bo na bazie platformy Android, RK3188 możliwości rozwoju komputerowych potężne, jak również do możliwości wsparcia DAC sprzętu 383kHz / 32bit, nie ma teoretyczne X7 nie obsługuje formatu muzycznego. Ze względu na android ramach oprogramowania, RK3188 potężna moc obliczeniowa procesora i układ 32-bitowy DAC / 384 kHz Funkcja konwersji ojczystym, bez wsparcia X7 Format pliku audio jest bardzo rzadkie. System składowania: Wbudowany w 32g szybkiej pamięci FLASH; Onboard 32Gb pamięci Flash. Wbudowany wysokiej prędkości 512MB pamięci RAM Program działa; 512 MB pamięci RAM na pokładzie Gniazdo zewnętrznej karty TF, obsługiwać do 128G. Teoretycznie wspierać przyszły 256G / 512G TF karty; Wsparcie zewnętrzne gniazdo pamięci microSD, obsługuje do 128 GB MicroSD Card. Wsparcia funkcji 256GB / 512GB karty MicroSD Pomoc cloud przechowywania; (potrzebujesz innego pójść w górę wsparcie poprzez upgrade oprogramowania) Pomoc Cloud Storage (To wsparcie Funkcja w przyszłości aktualizacji firmware) Wsparcie sieci DLNA transmisji; (trzeba poczekać na obserwacji wsparcia poprzez aktualizację firmware) Odtwarzanie dźwięku Obsługa DLNA (To wsparcie Funkcja w przyszłej aktualizacji firmware) NAS wspiera grę sieciową; (trzeba poczekać na obserwacji wsparcia poprzez aktualizację firmware) Wsparcie strumieniowe odtwarzanie dźwięku NAS (To wsparcie Funkcja w przyszłej aktualizacji firmware) Wired / Wireless: Sieć / bezprzewodowa obsługa sieci: Pomoc 2.4G WiFi; Pomoc 2.4G Wifi Odtwarzacz audio Bluetooth; Wsparcie odtwarzania urządzenie Bluetooth Obsługa USB 2.0 Połączenie danych; Transfer danych przez wsparcie USB 2.0 Obsługa USB 2.0 USB dekodowania wsparcie 192K / 24B asynchroniczne dekodowanie USB; Obsługa USB DAC USB 2.0 do komputera, obsługuje do 24Bits / 192kHz DAC USB asynchronicznych funkcji. Rozszerzone wsparcie bazy; Wsparcie dokowanie Zewnętrznych. Podstawowa konfiguracja sprzętowa: Na podstawie specyfikacji sprzętu: Mistrz: Rośnie Micro RK3188 zaawansowane procesie technologicznym 28 nanometrów procesor 1,8 g; półprzewodników 4-rdzeniowy. Procesor: Rockchip RK3188, procesor 1.8GHz 4 rdzenia RAM: 512MB Wbudowana pamięć: 32G ROM: 32G Ekspansja zewnętrzna: 128G karty TF. External Storage Extend: 128g MicroSD DAC Chip: ESS9018 8-kanałowy 384K / 32B DSD rozwiązanie sprzętowe Chip. Najwyższa na świecie wydajność, najdroższe DAC Chip; Uwaga: producenci telefonów stacjonarnych używany dekoder ESS9018K2M; DAC Chip: ESS9018 I / V konwersji: TBD I / V: TBD Filtr dolnoprzepustowy: Do ustalenia LPF: TBD Napięcie amplifikacji: W zależności od konfiguracji; Zysk AMP: Zależy od innego modułu Aktualny zoom: W zależności od konfiguracji; Aktualny AMP: Zależy od innego modułu Bateria wewnętrzna: 3700mAh bateria nie może być zastąpiony; Bateria wewnętrzna: 3700mAh, NIE wymienne. Czas życia: W zależności od mocy wyjściowej Konfiguracje / interfejsy. Do 12 godzin, najkrótszy 5 godzin; Żywotność baterii: .. W zależności od modułu interfejsu wyjściowego / Max 12hrs, min 5 godz. Prąd ładowania: Więcej niż 500mA, 2.0A Prąd ładowania zaleca się, aby uzyskać największą szybkość. Naładuj: Więcej niż 500mA, zalecamy używanie 2.0A do ładowania Wyposażenie standardowe: 1, linia danych; 2, zestawy do wody; 3, folia ochronna na wyświetlacz; Oryginalne niezależne części: 1, różne pomocnicze kabel wyważone słuchawkowe; 2 różne Moduł amp; 3, ładowanie kołyski amp; 4, zwyczaj wysokiej klasy zatyczki do uszu; Harmonogram wydania: Wydany plan: August 7, Hong Kong pokaż dźwięku zrobić statyczny obraz. 07 sierpnia: Wyświetlacz Dummy na HongKong Audiophile show. 13 września Guangzhou Fair ma nowego zestawu konferencyjnego; 13 września: spotkanie na temat produktów Wydany Pokaż słuchawkowe Kantonie 18 września w Pekinie Audio Show miał produktów; 13 września: Produkt Tryouts na Pekin Audiophile Pokaż Przewiduje się na koniec września dla użytkownika VIP i starych klientów preferencyjne sprzedaży; Szacunkowa Pod koniec września, Zniżka dla użytkownika VIP Promocji i po klienta Plan w październiku rynek krajowy. Grudniu przed świętami dostępne na całym świecie. Szacunkowa października Release w Chinach, Szacunkowa grudnia przed Świętami Bożego Narodzenia, w świecie Uwalniania Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Inszy Opublikowano 30 Lipca 2015 Zgłoś Udostępnij Opublikowano 30 Lipca 2015 To może i już mam prezent dla siebie... Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
hibi Opublikowano 30 Lipca 2015 Zgłoś Udostępnij Opublikowano 30 Lipca 2015 ciekawe połączenie Sabre i granie Fiio Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
all999 Opublikowano 30 Lipca 2015 Autor Zgłoś Udostępnij Opublikowano 30 Lipca 2015 Jednak Fiio potwierdza 1GB na chińskim forum. Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
VanCas Opublikowano 30 Lipca 2015 Zgłoś Udostępnij Opublikowano 30 Lipca 2015 Skoro jest oparte na Androidzie to ciekawe czy da się z niego coś wyciągnąć i portować na inne urządzenia z Andkiem Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
all999 Opublikowano 30 Lipca 2015 Autor Zgłoś Udostępnij Opublikowano 30 Lipca 2015 Skoro jest oparte na Androidzie to ciekawe czy da się z niego coś wyciągnąć i portować na inne urządzenia z Andkiem Co konkretnie chciałbyś portować? Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
VanCas Opublikowano 30 Lipca 2015 Zgłoś Udostępnij Opublikowano 30 Lipca 2015 Odtwarzacz, bo jeśli podmienić sterowniki to może się okazać, że Neutron i poweramp maja poważnego konkurenta. W sumie idąc dalej w strefę przypuszczeń wydanie przez Fiio aplikacji odtwarzacza na androida byłoby ciekawe gdyż całkiem sporo osób używa ich wzmacniaczy słuchawkowych z smartfonem. Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Gość Opublikowano 31 Lipca 2015 Zgłoś Udostępnij Opublikowano 31 Lipca 2015 Czas działania 5-12 h. Bida.Ekran jakimś Gorilla Glassem pokryty też by się przydał, a chyba nie ma info. Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
crysis94 Opublikowano 31 Lipca 2015 Zgłoś Udostępnij Opublikowano 31 Lipca 2015 Spokojnie ... obecnie mam kanapkę X5, E12A i PowerBank xD 1 Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
retter Opublikowano 31 Lipca 2015 Zgłoś Udostępnij Opublikowano 31 Lipca 2015 Spokojnie ... obecnie mam kanapkę X5, E12A i PowerBank xD A nosisz ją czy to tylko mini tor stacjonarny ? Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
crysis94 Opublikowano 31 Lipca 2015 Zgłoś Udostępnij Opublikowano 31 Lipca 2015 Mam dużą kieszeń w marynarce ... :| Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Gość Opublikowano 31 Lipca 2015 Zgłoś Udostępnij Opublikowano 31 Lipca 2015 Dorzucą tego typu spodnie w gratisie z powerbankiem Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Inszy Opublikowano 31 Lipca 2015 Zgłoś Udostępnij Opublikowano 31 Lipca 2015 Jeżeli można uznać to za spodnie Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
crysis94 Opublikowano 31 Lipca 2015 Zgłoś Udostępnij Opublikowano 31 Lipca 2015 Worek po kartoflach widzę, a te spodnie to gdzie? Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
retter Opublikowano 1 Sierpnia 2015 Zgłoś Udostępnij Opublikowano 1 Sierpnia 2015 To gacie dla siusiu majtków na sporego pampersa. Mam dużą kieszeń w marynarce ... :| Ta to pokazuj ... Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Gourney Opublikowano 2 Sierpnia 2015 Zgłoś Udostępnij Opublikowano 2 Sierpnia 2015 Taka Kryzysowa kanapka to bez łaski do każdej marynarki wchodzi:-). Co do x7 - biedny ten czas pracy na baterii, dla mnie coś co nie zagra przynajmniej 7h w ciągu dnia (bez konieczności ładowania) nie ma sensu kupować. Jedyne co mi zostało to liczyć na jakiegoś następcę HSA Studio. Wysłane z mojego ALE-L21 przy użyciu Tapatalka Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
retter Opublikowano 2 Sierpnia 2015 Zgłoś Udostępnij Opublikowano 2 Sierpnia 2015 Ta już widzę ja bym x5c5 nie włożył do marynarki a + powerbank , niestety do marynarki zostaje dobry telefon + iemy, na luzaku to inna bajka ... Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
crysis94 Opublikowano 2 Sierpnia 2015 Zgłoś Udostępnij Opublikowano 2 Sierpnia 2015 Może nie sprecyzowałem ... to nie jest ubiór odświętny, na co dzień noszę matową marynarkę Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
retter Opublikowano 2 Sierpnia 2015 Zgłoś Udostępnij Opublikowano 2 Sierpnia 2015 A co to ma do znaczenia ? 4-5cm kanapka i tak będzie mocno odstawać, nie po to ludzie kupują szyte na miarę garnitury jako uniform aby coś im tam odstawało na 4-5cm Widziałem nawet portfele podzielone na 2 części do kart plastików i większych nominałów oraz drugi na drobniaki. Ale offtop doba dalej nie spamuje tu ... Wie ktoś jaki to ma być amp pod IEMy oraz ten normalny co on tam uciągnie ? Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
all999 Opublikowano 6 Sierpnia 2015 Autor Zgłoś Udostępnij Opublikowano 6 Sierpnia 2015 2 Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Inszy Opublikowano 6 Sierpnia 2015 Zgłoś Udostępnij Opublikowano 6 Sierpnia 2015 Ciekawa rzecz na tym zdjęciu - grajek z wyższej półki, a utwór 128kbps. Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
