Fanklub wielbicieli słuchawek planarnych
Baele
Audeze wypuściło darmowy plugin. Starczy podać mejla, by ściągnąć.
https://www.audeze.com/audeze-reveal-plugin#
Info i wątek na headfi: https://www.head-fi.org/threads/dsp-for-audeze-headphones.864146/#post-13822515
Wymagane: macOS (10.10 i wyższe), Windows (7 i wyższe), DAW, odtwarzacze obsługujące AU, VST i AAX pluginy.
Działa z dużym zakresem samplerate (44.1 kHz - 768 kHz).
informacje dodatkowe:
"You need a VST wrapper/adapter component installed in fb2k to enable VST plugins." źródło: https://www.head-fi.org/threads/dsp-for-audeze-headphones.864146/#post-13824350
 ( http://wiki.hydrogenaud.io/index.php?title=Foobar2000:Components/VST_adapter )
Pierwsze opinie o pluginie:
"Nice plugin, the iSine 20 still has a hint of the midrange bump that can make vocals sound a bit honky at louder volumes, but for other songs the VST makes vocals sound effortless. I'm using the VST plugin with yohng's VST wrapper for Foobar2000 and it works great, it's a fairly easy setup." https://www.head-fi.org/threads/dsp-for-audeze-headphones.864146/page-2#post-13825931
"great plugin.I advise you all to lower the output gain at least by 4dB to avoid clipping.In Jriver for example with sox oversampling enabled on pcm sources and the reveal plugin engaged the overflows get to 115-120% with very loud recordings if you keep the gain of the plugin at 0 dB " https://www.head-fi.org/threads/dsp-for-audeze-headphones.864146/page-2#post-13828412
"This plug in is working beautifully with my isine 20. " https://www.head-fi.org/threads/dsp-for-audeze-headphones.864146/page-2#post-13828065
"With a 2014 LCD-XC the initial impression is a darker flavor to the tonality.
With a 2017 LCD-X a little darker and more subbass too. " https://www.head-fi.org/threads/dsp-for-audeze-headphones.864146/page-2#post-13830612
Cytuj
and features the slightly warm sound signature of the original LCD2 driver.
Lcd2-classic, to one mają być jeszcze cieplejsze? LCD2 driver słuchałem na AVS i już to był bardzo soczysty ciepły dźwięk.
6 godzin temu, saudio napisał:
Już trzeci raz się kręci Interstellar, świetna realizacja i pięknie oddana potęga instrumentu jakim są organy.
Na HE1000 przestrzeń, dynamika, czystość robi wrażenie. Zwłaszcza na finale Coward.
Dobry człowieku, jak mi brakuje takich opinii! Bez rozpisywania się na zakresy, przełomy średnicy itp. Jak ja dawno nie przeczytałem tekstu tutaj w takim tonie jak ten: piękna muzyka, na moich słuchawkach pokazuje to i to cudnie. :)
LCD-2C nie będą sprzedawane w Europie... informacja pochodzi od samego Audeze (ze stoiska Canjam Europe - Berlin), więc wydaje się wiarygodna.
źródło: https://headfonics.com/2017/11/canjam-europe-2017-show-report/
Co do tego jak grają, to na razie dużo opinii nie ma, więc trudno jednoznacznie stwierdzić, ale z tego co czytałem to mam wrażenie, że Ci co pisali, że będą grać jak LCD-X to dużo się nie mylili. Sygnaturka to chyba będzie pomiędzy LCD2, a LCD-X i to są prawdopodobnie przetworniki LCD-X bez fazora.
Nowe recki planarów:
http://earphiles.org/2017/11/acoustic-research-ar-h1-review/
http://earphiles.org/2017/11/mr-speakers-aeon-flow-open-review/
Jakoś nie jestem przekonany, czy takie firmy widzą w tym kontynencie jakiś super rynek :P Zobaczymy też, ile tego naprodukują, jeszcze się okaże, że to jakieś popsute egzemplarze/części LCD-X czy coś :lol:
Edytowane przez oblivion
To skąd mp3store ma ich cenę na nasz rynek?
Nie mnie pytaj. Z artykułu, który wyżej dawałem, jego autor miał usłyszeć na stoisku Audeze, że w Europie ich sprzedawać nie będą, dlatego ich nie ma na pokazie: "Their LCD-2C were not shown as I eavesdropped on a conversation and heard that these headphones are not to be released in Europe." ( https://headfonics.com/2017/11/canjam-europe-2017-show-report/ )
Oczywiście jest jeszcze nadzieja, że pracownicy Audeze nie ogarniają tematu :P
Wg pierwszych opisów ludzi tak nie grają, obstawiam więc, że info od Audeze to zwykły marketingowy bełkot i rację mogą mieć osoby, które od samego początku obstawiały, że skoro parametry przetworników są jak w LCD-X to będą bliżej do nich miały niż do starych LCD2. Być może to dobry sposób by sprzedać zalegające LCD-X (było już na nie trochę dużych obniżek jak pamiętam) :P
A jakie parametry są jak w LCD-X?
Bo wg. parametrów to im bliżej nawet do LCD3 niż X, więc... to chyba pobożne życzenia z tymi X za 2100zł? :)
Jak dla mnie to będą ciepłe, basowe kluchy, dokładnie tak jak stare LCD2.
Edytowane przez Karmazynowy
Tego to jeszcze nie wiadomo :). Fazor to nie wszystko, kiedyś używali innych materiałów, ale jak się psuły po pewnym czasie to zaczęli zmieniać na inne i według niektórych gorzej grały, ale nie psuły się. Jest to nawet poparte pomiarami, że rozrzut tam spory mieli. Oficjalne stanowisko Audeze jest takie, że te nowe to są teraźniejsze 2 bez Fazora więc nie muszą grać tak samo jak te stare.
Czyli słabsze granie LCD -X...Ha,aha,,ale się ludzie nabiorą...będą oczekiwać wspaniałego ,nasyconego przekazu, LCD2, basowego mistrzostwa a dostaną popłuczyny po LCD -X....ha,ha,...ale będzie w komisie słuchawek.....he,he.
  • Haha 1
Obecnie to masz rację, teraz mają wg opisu 70ohm, a wcześniej podawali ~20ohm, czyli podobnie jak w LCD-X.
To nie pobożne życzenie, bo sprzedaż i tak się im będzie opłacać, no i za wielką wodą były na nie bardzo duże obniżki, nie pamiętam ile dokładnie, ale gdzieś taniej o połowę. Więc coś mam wrażenie, że sprzedaż LCD-X nie idzie za bardzo.
Druga sprawa, jakie 2100zł? :o Ich (LCD2-C) cena wg strony Audeze to 799$, czyli byłoby to w Polsce pewnie około 3500-4000 złotych...
