Fanklub wielbicieli słuchawek planarnych
Baele
W skrócie:
More comfortable than HE400i and HE400s
Poor quality stock cable
Matched volume at 100hz
He4XX vs He400:
tighter bass on 400, everything else better on 4XX
Overall 4XX more refined and more articulate
4XX Less grain, cleaner but more fatiguing
more dynamic, more fun, more correct sound in 4XX
400 more soundstage
HE4XX vs HE400i:
400i more sub bass presence but less bass overall
4XX more punchy and fast
4XX less fatigue, smoother
4XX Better imaging more soundstage
HE4XX vs HE400s:
He4XX more bass, faster stronger bass
Mids equal/same
HE4XX more sparkle and presence
HE4XX vs M1060:
4XX better headphone, better value
M1060 more bass, less controlled
4XX destroyed M1060 in every other aspect
Did not expect this much from entry level headphone
Not worth side-grade from 400i or 400s if you are satisfied already.
Z ciekawości to ktoś się szarpnął na HE-4XX, bo nawet po doliczeniu VAT wydają się dobrym dealem
Co my tu mamy?
Chamska podróba Hifimana z elementami Audeze i Beyerdynamika...
A ten peak na 1,5kHZ, masakra.
Jeszcze są Sto Szóstki
https://pl.aliexpress.com/item/106MM-plane-Magnetostatic-Headphones-balanced-version/32787508555.html?spm=a2g17.10010108.1000013.3.3fda74d34112EW&traffic_analysisId=recommend_2088_2_81019_new2&scm=1007.13339.81019.0&pvid=0c30bf66-55bf-4264-9dfb-024fa59091e5&tpp=1
Z innym wykresem ale i wyższą też ceną.
Jest pełno aukcja z cenami z du... Nie widzę, by ktoś kupił chociaż jedną sztukę.
Przykłady innych z chorymi cenami:
https://pl.aliexpress.com/item/Adjustable-Super-Bass-Wood-Headphones-Hifi-Soundproof-Over-Ear-Noise-Canceling-Dynamic-Computer-Headset-Casque-Audio/32796330987.html?spm=a2g17.10010108.1000014.5.3fda74d3pzXqw1&traffic_analysisId=recommend_3035_3_86013_iswiall&scm=1007.13338.86013.0&pvid=f4265770-b673-4f6b-9b7a-eff984414264&tpp=1
https://pl.aliexpress.com/item/Call-center-telephone-headsets-Good-quality-single-side-headphone/2034089620.html?spm=a2g17.10010108.1000014.31.3fda74d3pzXqw1&traffic_analysisId=recommend_3035_16_86013_iswiall&scm=1007.13338.86013.0&pvid=f4265770-b673-4f6b-9b7a-eff984414264&tpp=1
I jeszcze zauważyłem, że na allegro u niektórych sprzedawców powstała praktyka, że kilka aukcji mają z ceną 10x, a nawet 50 razy większą niż identyczna rzecz u innych sprzedawców. Liczą, że ktoś się nadzieje i zarobią.
Co do wykresów to nie ma co wierzyć, bo jak widzę różne pary słuchawek mają podany ten sam wykres, np.:
https://pl.aliexpress.com/item/Metal-fever-headphones-53mm-driver-360g-super-Classical-music-performance-HIFIMAN-gold-plated-mother-seat/32701181711.html?spm=a2g17.10010108.1000013.9.3fda74d3pzXqw1&traffic_analysisId=recommend_2088_5_81019_new2&scm=1007.13339.81019.0&pvid=5e00d45f-4e36-446c-b48c-0c6acd8a5280&tpp=1
https://pl.aliexpress.com/item/DIY-53MM-driver-Rosewood-Fever-headphones/32818896769.html?spm=a2g17.10010108.1000013.5.3fda74d3QqIGBy&traffic_analysisId=recommend_2088_3_81019_new2&scm=1007.13339.81019.0&pvid=2d9c5be4-50a1-4529-a11c-9bba4ae6daeb&tpp=1
Edytowane przez oblivion
To chyba lepiej już kupić jakąś samą obudowę audeze-podobną jak tu https://pl.aliexpress.com/item/50mm-headphone-shell-headset-housing-wooden-shell/32818400153.html?spm=a2g17.10010108.1000015.81.3fda74d3pzXqw1     Będzie mniej kasy w błoto :P
Z chińczyków(albo raczej niebrandowych słuchaw czy nowo-brandowych) to w tej chwili mam na uwadze jedynie sivga 005 i 007, ale to nie planary, więc więcej nie piszę tu o nich :P
Ups sory nie zauważyłem, właśnie coś mi nie grało patrząc na ich wygląd :D UPDATE: Już przekreślone, by w błąd nie wprowadzać ;)
A właśnie nawiazując do udanych Bosshifi B8, to jest jeszcze wersja otwarta/półotwarta B7 - ale ta akurat ponoć im nie wyszła, dlatego jak wyżej pisałem jestem zainteresowany bliźniaczą konstrukcją Sivga 005 lub podobnymi 007 - ponoć te modele nie są złe.
  • 3 tygodnie później...
Witam.Panowie czy ktoś miał do czynienia z HiFiMan HE-Adapter? Czy nada się to do podłączenia Pm-2 z HA-1A?Boję się że rozwali słuchawki.Kupiłem kabel zbalansowany na zapas pod [Aune s6 będzie na początku roku] i chciałbym z niego póki co korzystać.Koszt przejściówki xlr 4pin na jack[firmowa] wychodzi połowę ceny tego urządzenia.https://www.q21.pl/hifiman-he-adapter.html Może jakieś inne sprawdzone sposoby?
